Fatal error: protocolsup.cpp
Excuse me... my cRio controller is 9002
Message 21 of 34
(4,270 Views)
I can get my hands on a 9002 and run your code. Go ahead and post a simple VI that will reboot a controller whenever you can. Smiley Happy
Charlie M. CLD
Message 22 of 34
(4,260 Views)
This is the simply VI.... It cause to happen the reboot of the cRio and if I use the highlight execution I remain in the first block.
After the reboot loose the connection with RT
Message 23 of 34
(4,251 Views)
Hello Fabio,
I ran your VI on a 9002 controller as well as a 9004 controller without any issues. You mentioned that you were using LV RT 8.2.1 is that still valid? I used LV RT 8.5 when I ran your VI.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 24 of 34
(4,224 Views)
yes, I'm using LV RT 8.2.1
Message 25 of 34
(4,220 Views)
Hello Fabio,
I am afraid that it is a known issue in LV RT 8.2.1, and it was fixed in 8.5 (like one have already mentioned in this very thread). I am not sure if we can provide a workaround for this in 8.2.1 or not. Hopefully we can get a clarification about this from my colleagues in the US that have posted in this thread since they have closer contact to R&D.
Jimmie Adolph
Message 26 of 34
(4,216 Views)
thank you very much
Fabio
Message 27 of 34
(4,206 Views)
Hi all,
I have similar problem here, error at protocolsupp.cpp fatal internal error line.
I am using LV 8.5 RT, and PXI-7358 motion controller.
Does anyone has the solution for this yet? It is very urgent 😞
Thank you
Message 28 of 34
(3,612 Views)
The only approach that I ever got to work was just not highlighting execution and not stepping through the code.  Instead I use some form of logging.  Yes, it's really irritating.
Message 29 of 34
(3,600 Views)
Hi bono02,
Can you post your error log? What line is the error occurring at? If you're not sure where your error log is located, the directions are here.
Hillary E
Message 30 of 34
(3,586 Views)
