Feature "labview" (in license file ) has a problem. Cannot find SERVER hostname in network database ("WinSock: Host not found (HOST_NOT_FOUND)")
I did uninstall both versions that I had of Labview and now I installed first the older version, 6.1; however it still is displaying me the next message when I'm trying to open it:
Feature "labview" (in license file ) has a problem. Cannot find SERVER hostname in network database ("WinSock: Host not found (HOST_NOT_FOUND)"Smiley Wink
What does it mean? Is there something wrong with the license? What do I need to do next?
(2,701 Views)
Please stick to the original thread, so others can follow this. If you have an urgent problem you should contact NI Tech Support directly.
Message Edited by smercurio_fc on 10-23-2008 01:36 PM
(2,694 Views)
