Feedback note - what's wrong?
I tried to write a VI such that everytime when the OK button is pressed, the numeric indicator will increment one.
But it doesn't work as expected.
I am using feedback node method.
Please help.
(3,560 Views)
Why not use an event structure instead?
Bill
CLD
(Mid-Level minion.)
(3,559 Views)
Event structure cannot be used in my context.
(3,551 Views)
So, you're saying you are being forced to do it this way?  Like, as an example, for an assignment?
Bill
CLD
(Mid-Level minion.)
(3,545 Views)
Accepted by splee
it seems you are using "continuous run" mode, which reinitializes yor feedbanck node wkth every auto-restart. place a while loop with a delay around your code and use the regular run button.
(3,543 Views)
It get reinitialize every time you press ok so you will always get the same value at the output.
Ben64
too late, Altenbach already responded!
(3,540 Views)
