Fgen Arbitrary Waveform example not working
I'm using an example for NI FGEN - "Fgen Arbitrary Waveform". I want to enable digital filter, but there is an error occures. What should i do to fix this error?
(3,945 Views)
bahec666,
What FGEN model are you using? Please refer to the Signal Sources help file to see if your model of FGEN supports digital filtering.
(3,906 Views)
I'm using NI FGEN 14.0 with NI PXIe-5451 signal generator. They are support digital filtering.
(3,899 Views)
Accepted by bahec666
bahec666,
The PXIe-5451 does not support digital filtering.  That is why you are getting the error message you are seeing.
(3,873 Views)
