Fieldpoint Error------------Access denied: This target is running version of LabVIEW Real Time is different than the Real Time Module Software on the host computer. You can verify the version and reinstall the real time software using MAX”
Prashant Soni
LabVIEW Engineer
(3,609 Views)
Hi Prashant
What exactly were you wondering about with this post? The error message you are getting is otherwise pretty clear, the LVRT version installed on the Fieldpoint controller is not the same as on you computer. They need to be the same. You can find which version is installed where in MAX, under My System->Software for your PC and under Remote Targets -> [Your Fieldpoint Controller] -> Software for the Fieldpoint. You then have two options:
1. Update the Fieldpoint software (make sure the the Fieldpoint controller is compatible with the version on your PC first)
2. Reinstall the verison already on the Fieldpoint on your PC.
Best Regards
David
NISW
(3,604 Views)
