File conversion from LVM to TDMS?
Hello forum members,
Does anyone has an idea on how to convert from LVM file to TDMS?
I will really appreciate your help on this
thanks again
SergeArmz
Message 1 of 8
(5,462 Views)
Hi Serge,
read your LVM file and save it using TDMS functions?
Message 2 of 8
(5,459 Views)
I think that is going to depend on how your LVM file is formatted.  The writing to TDMS is quite straight forward and just use the TDMS Write function giving it the proper data, channel and group names.
Reading the LVM shouldn't be hard, just understanding the pieces.  I think LVM is just a text file with some header information, then tab delimited data.  Read all the data, turn it into arrays, then write to TDMS.
https://www.ni.com/en/support/documentation/supplemental/06/specification-for-the-labview-measuremen...
Post an example LVM file and code if you get stuck.
Message 3 of 8
(5,456 Views)
Hello GerdW,
Thank you for your reply, do you have any sample on how to do that?
Serge Armz
Message 4 of 8
(5,455 Views)
I asked you first Smiley Tongue  You're not giving us much information, so any answer we give you is probably going to be incomplete or may not work in your situation.  For best results, give us all of the information you can.
Message 5 of 8
(5,438 Views)
Yes, you are right Hooovahh,
I'm attaching a sample fLVM file, I use to acquire 1 second at 48KS/sec, so basically my file contains 48,000 points, what I'd like to do is to convert it to TDMS, but i do not really have an idea on how to do that Smiley Sad
Thanks for your inputs
SergeArmz
Message 6 of 8
(5,425 Views)
Accepted by SergeArmz
As much as I hate express VIs, it sure made quick work of what you wanted.
Using Snippets
Message 7 of 8
(5,411 Views)
This really works, thanks Hooovahh Smiley Wink
Message 8 of 8
(5,398 Views)
