File dialog trimming the default name
I use the filename pre-filled in the case of the user selecting the "Save As" option in my application. For loading a file, I leave the filename empty.
Hi, thanks for the post.
I will do the same thing, although this could be a bit annoying for my some of my users. On saving I have to live with this not customizable or translatable "replace file dialog box" in the case of replacing of the file.
Message 31 of 34
(1,132 Views)
I just hit this bug (in Windows 11 since no-one has yet updated this thread with the fact that it still exists there). Thankfully, the workaround presented as the solution not only worked, but also highlighted to me that in selecting the option "New or existing" that I thought I wanted, I'd actually chosen wrongly since "New" is the correct option to choose to allow the choice of a new or existing file with a warning prompt to overwrite an existing file. So double-thanks (and kudos) to the original poster (who is probably long-gone in the intervening decade). This behaviour could be more clearly described in the documentation (although in fairness I doubt I would have read it closely enough anyway). Perhaps instead of "New—The user only can enter the name of a new file or folder," which is not true, it could better be labelled "New (warn on existing)". Either way a good outcome thanks to this forum.
Message 32 of 34
(945 Views)
Original poster here 🙂 Still working in LabVIEW even a decade later 🙂
Glad to hear the workaround helped! (and surprised the issue still has not been fixed in Windows 11...)
Message 33 of 34
(917 Views)
... and it's still a problem in LV 24.3.1f1 ... so many years later than the original post!
Also, the accepted solution worked well for me.
Message 34 of 34
(249 Views)
