File does not begin with '%PDF-'. error when opening PDFs from Labview Help
I have Labview 7.1 and Adobe Reader 7.0.1 installed on my computer. Whenever I click a link to a PDF file in Labview's Help files, I get a "File does not begin with '%PDF-'." message and the PDF will not open. Adobe Reader works perfectly otherwise.
It seems that all the links in the documentation are of the form
javascript:AcrobatLink('../manuals/lvuser.pdf');
I'm guessing that Adobe Reader 7.0 is interpreting this as a file with a "pdf');" extension instead of a "pdf".
I find it odd that I cannot find any other reports of this problem (except at http://forums.ni.com/ni/board/message?board.id=170&message.id=106901&view=by_threading&page=2). Is there an obvious way to fix this difficulty, or is this a matter for Adobe?
(26,530 Views)
I have Acrobat Reader 5.1 at home and 6 at work and both work fine with the LV 7.1.1 bookshelf and help file. The PDF-files itself have the %PDF-1.x signature at the beginning. I haven't tried Acrobat Reader 7 so it could be an Adobe problem or a new interaction problem.
You can reach the PDF-Files also by using Help>>Search the LabVIEW Bookshelf. Does this link work for you?
This is a call to a java script function located in pdf.js.
Other reasons:
The Active-X control of Reader 7 has a bug.
Your Internet security settings will not allow this operation. The Active-X will be loaded but will have no access to the file and yo get a wrong error message.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(26,523 Views)
Thanks a lot for replying.
Yep, I just uninstalled Adobe Reader 7.0 and installed version 6.0.1. The links now work perfectly, so evidently this is a problem with Adobe Reader 7.0. I'd still like to solve the problem, though, as I really like version 7.0. (Something has finally been done about the program's lengthy start-up time!)
It works perfectly.
Other reasons:
Fair enough. If that is indeed the case, which Internet security setting should I try changing? I haven't done anything unusual to any of those settings. And where is pdf.js located? I tried searching for it but could not find it.
Your advice is greatly apreciated.
(26,510 Views)
Hi kehander,
I tried to reproduce the behavior that you are describing, but my combination of LabVIEW 7.1 and Adobe Reader 7.0.1 works perfectly. Nomatter if I launched the PDF-file from Windows Explorer or through the "Help >> Search the LabVIEW Bookshelf..." link, the document would open without any issues.
If you are able to reproduce the error when reinstalling Adobe Reader 7.0.1, please submit a detailed description on how you get the error - exactly where you are clicking the link etc.
Thanks!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(26,504 Views)
This is the simplest way for me to produce the error:
Go to Start -> Programs -> National Instruments -> Labview 7.1 -> VI, Function, & How-To Help
Click the "LabVIEW User Manual" link
The error occurs regardless of whether I am logged in as an Administrator or not.
I just did some poking around with Filemon and have determined that Adobe Reader is successfully accessing C:\Program Files\National Instruments\LabVIEW 7.1\manuals\lvuser.pdf (which also opens flawlessly if I open it normally); it is not a problem with incorrect filenames as I first surmised.
Filemon also indicates that the major difference between when lvuser.pdf is accessed normally (such as through Start -> Run, or with Internet Explorer) and when it is accessed through Labview Help is that with Labview Help, Adobe Reader writes to a file named C:\Documents and Settings\[User]\locals~1\temp\acrXXX.tmp, where XXX is some combination of alphanumerics. This file does begin with %PDF- and can be opened with Adobe Reader if copied and renamed.
If none of this sounds remotely familiar to anyone, I suppose I ought to take this problem elsewhere, as I seem to be digressing from Labview. 😉
(26,493 Views)
Problem solved!
Adobe released a 7.0.2 update last Tuesday. After installing it, the error has been eliminated. How about that? 🙂
(26,464 Views)
I've had the same problem... I'm downloading 7.0.2 right now!
Thanks for the help,
mlloyd
(26,456 Views)
