how to clear power up reset states?
Hi everybody,
I'm facing a problem with the motion control system, the system kept contiune showing us that the system is in power up state. we run the clear power up reset state program but we still could not solve the problem. Is there any other solution to provide me to solve this problem. what are the problem that actually cause this error state? this problem dose it related to our hardware connection or software setting?
thanks for helping.. really need the help...
(3,549 Views)
Hey Kuroro,
Usually when you call and run the clear power up reset state program, it should take care of resetting the state of the board. The next step to try is after you have run the clear power up reset state is to initialize the board itself. Go ahead and try to reinitialize the board after you call this clear power reset state program. You can either initialize the board in the Measurement and Automation Explorer, or you can use the function in Labview to do this. You can just use the Initialize Controller VI to do this.
Please let me know if this works or not. Usually initiallizing the board after calling the Clear Power up Reset State VI solves the issue. Keep me updated on what else is going on, i.e. what errors you are seeing or what else is going on with the hardware. Thanks, and have a great day.
DJ
(3,521 Views)
Thanks DJ L.
The problem at last was solving. I think the problem was our driver was broken, after we change new driver, the robot can move again, i am so happy now.
(3,506 Views)
Hey Kuroro,
I am glad to hear that you were able to get your motion application working again. Good luck with the rest of your application. Have a great day.
DJ
(3,490 Views)
