File explorer type display and csv contents display
I am working on the a project to save the reports in CSV format for tests done, which is saved in respective 'date' folder (the date when test is done).
I want to have a display as shown in image below:Report window.JPG
I am not able to figure how to display the:
1. File Present Panel: To display all the csv file present in a particular folder.
2. Test Data Panel: The CSV data contents on clicking on a particular file.
Since, I am new to LabVIEW would appreciate your help.
Thanks.....
(2,711 Views)
Hi Kunal,
1. Use a Listbox to display the filenames of the files found in your datafile folder. (Did you already notice that ListFolder function?)
2. Use a Table to display the content of the file selected in the listbox.
What have you tried? Where are you stuck?
Did you notice the Training section in the header of this LabVIEW board?
(2,702 Views)
Accepted by topic author KunalSati
Thanks GerdW,
I tried using ActiveX controls, to use excel application type display to show the report file contents, but was getting too complicated.
For the listing the files saved, I was looking for file explorer type display, didn't knew about List Folder.vi.
Thanks again.
(2,679 Views)
