File not found error when checking file into SCC
I am attempting to setup the built in source code control features in Labview 7.0. I set up the master directory and my working directory. I copied the project I was working on into my working directory and opened the top level V.I.. I was able to successfully add it to the SCC. Then I was able to check it out and modify it. However when I check it back in I get the following error:
Error 7 occurred at Invoke Node in Version Control CIN.vi->SCC Enter Change Comments.vi->Builtin SCC Checkin.vi->Builtin SCC Checkin GUI.vi->Check In.vi
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use
\ as path separators on Windows, : on Mac OS, and / on UNIX.
NI-488: Non-existent board.
The path for my master directory is C:\temp\TestSCC and the path for the working directory is C:\temp\LVWD. I am able to undo check out, but I cannot check it back in with out getting this error.
I am using Windows 2000 5.00.125
Can anyone help?
Josh
(3,043 Views)
There are some strange things that occur with the SCC. See the following posting and the comment from NI which suggests to clear the revision history.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000FEE20000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Error+7+SCC&USEARCHCONTEXT_QUESTION_S=0
If the link doesn't work search on terms Error 7 and SCC it will be one of the first ones.
See also DevZone article titled: "LabVIEW 6.1 Source Code Control Doesn't Recognize Local Changes when Revision History is Used"
I found that the same thing still ccurred in LabVIEW 7. Not sure about LabVIEW 7.1
(3,043 Views)
