File transfer option in MAX RT
Hi!
When  right-button clicked upon RT-target's IP-address in MAX on Host, I didn't find "file transfer" option.
What component should be added on Host for this option to appear whithout installing all PDS and RT packages?
Thank you.
(3,633 Views)
I don't know what is missing in your installation, I thought this option is added when installing LabVIEW RT.
Anyway, you can use any FTP tool (e.g. FileZilla) to transfer files between host and RT.
(3,619 Views)
Accepted by topic author TerraNova
TerraNova,
Did you enable the option mentioned in this Knowledgebase article?
Dan_u is also absolutely right you can use any other ftp client including Windows Explorer.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,604 Views)
