Files in Executable
Hi
I have a project where i start some files who are saved on my laptop. But when i create an executable from my LabView program everything works fine. But when i copy the files to another laptop and start my code it will not work. This is because the files aren't stored in the directory on my other laptop. So how can i define where the program should get the files on all laptops with no problems?
Kind regards,
(2,875 Views)
Accepted by VH_NIELS
Hi VH,
What about using a fixed (network) folder on your local/company file server?
What about storing/installing the files in a fixed folder available to all users of a computer, like "CommonAppData"?
What about storing/installing the files in a subfolder of your executable's installation path?
What have you tried so far?
(2,864 Views)
Hi
The goal of the executable is just to get it on an USB stick and put it into another computer and run. So ideal would be that the files are in the directories of the executable. But i don't know how to do it.
Kind regards
(2,855 Views)
Hi Niels,
LabVIEW executables expect the LV-RunTimeEngine installed on the computer to be able to run, so just putting a LabVIEW-made executable on a memory stick might not work in all possible situations…
Include those additional files in your project. Then add them as "Always required" in the AppBuilder specs for your executable to get them added to the "data" subfolder next to your exe…
(2,850 Views)
Hi
And is there an posibility to use files without an path? Just by the name off the file?
Kind regards
(2,846 Views)
@VH_NIELS wrote:
Hi
Kind regards
Kind of, it'll be a relative path. It's good to use App-dir and build a path to reduce mistakes though.
Qestit Systems
Certified-LabVIEW-Developer
(2,809 Views)
