Fill points in a 2D graph
Hi there
I have a bunch of data points in a 2D plane that make a closed shape (a hexagon for instance ) if they are connected to each other. This data could be as simple as bunch of random numbers in a 6x2 matrix. I want to connect these point to each other and fill the shape that comes out of them. Any ideas?
(4,276 Views)
I would start with a picture control and try out the Draw Multiple Lines.vi.  You might get lucky, or you may have to do a little work to order the points correctly.
(4,271 Views)
Thanks but I want it to be a graph, not a picture. Pictures look so unprofessional to me!! I can do this easily in Matlab but I'd prefer it to be done inside LabVIEW rather than calling a Matlab script.
(4,259 Views)
Accepted by AliEskan
Well, phase 2 after you figured out the Draw Multiple Lines VI is to add the picture to a graph....
21061iC28910524E5F22B8
21063iA2A3D376E09DF19D
(4,253 Views)
Thank you, this is exactly what I was looking for.
(4,236 Views)
Is it possible to do the same thing for a 3D graph too? If yes, please let me know how.
(4,207 Views)
