Filter error: 20023
Hi everyone.
I am writing a code where I use a filter function. First i used filter from signal analysis-express. I got 20023 error. I belive my values are okay, although I use very small rate and  s to read.
Then with ptbypt I get very different chart (in foto). And with simple filter in last code i see nothing in chart.
I have looked at prevoius forms in community and tried these methods based on them.
Thanks in advance
(972 Views)
Accepted by Natig
Hi Natig,
The error message is quite clear!
Why don't you define any frequencies on your filter functions?
  • Why do you need ExpressVIs (aka FromDDT) to get the sample data from a waveform? Use waveform functions!
  • Why do you need to concat an empty array?
  • Why do you need to fiddle with t0 of the waveforms when you don't use any of the timing information later on???
  • Why are there loop running forever in a Windows application?
(952 Views)
Accepted by Natig
@GerdW wrote:
Hi Natig,
I think there is a misprint with the error message, if I am remembering correctly, rather than <= fs/2, it should read < fs/2. I think if you put the Nyquist frequency in you get an error, you have to put in something slightly less. I don't have LabVIEW to test.
(918 Views)
Thank you very much, your comments helped me to improve my code. It appears I did not needed some of the things there. I used sample codes from examples sometimes so I had some unuseful parts in code.
(869 Views)
