Filtering TCP Errors for network disconnection
I'm going to deploy some RT code to a FieldPoint control module, and the program needs to be able to run properly when the controlling PC is disconnected from the FP hardware.  To this end, I'm looking to filter TCP network error code from my program.  So far as I can see, errors 56 and 59 are the only two I need to ignore.  Is this correct?
(3,049 Views)
Hi Jeff,
see this link please: http://zone.ni.com/reference/en-XX/help/371361B-01/lverror/error_code_ranges/
It seems that there are some more errors defined by NI. Smiley Happy
Mike
Message Edited by MikeS81 on 06-10-2008 06:29 PM
(3,045 Views)
If you are using any NI Service Locator stuff, 1510 is one you probably want to look at.
(3,042 Views)
Thanks for the list, Mike
And Steven, I'm just using hard coded IP addresses and ports.  Open Connection, TCP Listen, stuff like that.
(3,037 Views)
