Find Active Library
When a VI's window is active, and you select an item from the tools menu, the VI that runs the tool can use this to get to the active VI:
However if a library window is active when a tool is called, "Application:Menu Launch:VI" returns "_ProjectWindow2".
Is there a way to get a reference to the library from that?
(1,479 Views)
Accepted by topic author paul_a_cardinale
This works:
(1,430 Views)
Nice, I did not know each library window belonged to its own temporary project!
This is weird because the library window title still indicates the actual project and target names:
(1,399 Views)
My guess is that LabVIEW needs to do that in order to present the library in its own tree.
(1,386 Views)
