Ni VISA 15.0.1 Installation Failure
Thanks for any help you can give me.
The instalation of WindowsInstaller-KB893803-v2-x86.exe from NIVISA1501full.zip fails with the error "Setup Error. Not enough memory resources are avaiabe to process this command".
The error from Setup.exe is "ConfigInfo.cpp(2902): InstallerError 10004
Fatal Error. Operation aborted.
Initialization aborted."
I have tried 2 PCs.
NI VISA 24.8 installs ok.
(711 Views)
Accepted by topic author Billo74
The application that needed 15 and would not work with 24.0 has worked with 24.0 so I no longer need to get 15 to install.
Thanks to the members who have viewed this item.
I am new and I can't find how to close this Item so far, I wil keep looking.
(674 Views)
Closed by accepting my reply as the solution.
(671 Views)
