Find and Replace Mutliple Criteria
If I do a find and replace on a enum constant, can I have multiple criteria?  Right now, when I do find, the only criteria is enum constant object.  I want to find all enum constants with the label "enum123" from main.vi and replace them with a type-def enum.
Right now, when I do search, I can only specify the object type (enum), so I am getting all enum object in the vi, which I don't want.  I just want enum objects with label "enum123".
Thanks!
Kudos and Accepted as Solution are welcome!
(2,817 Views)
If you search for text, you have this option, but you won't be able to do a simple replace.  The More Options lets you clarify where to find the text.  But, you'll have to manually replace the objects.
(2,812 Views)
Accepted by jyang72211
It would be nice if you stuck to your original post http://forums.ni.com/t5/LabVIEW/Find-and-replace/td-p/1705646
(2,803 Views)
I thought my question was getting too branched out.  Thanks for answering my question.  I will try to keep the questions in one place.  Thanks!
(2,794 Views)
