Find latency between two digital input signal raising edge's & falling edge's continuously on multiple samples
HI,
I am trying to find the latency between two digital input signal raising edge's & falling edge's continuously on multiple samples.
Attaching the VI's
tried multiple methods but could not get it
(673 Views)
What DAQ device(s) do you have available for this?  I'd highly recommend you look into a counter task doing a "Two Edge Separation" measurement if you have a DAQ device to support it.
-Kevin P
(641 Views)
1. i am using cDAQ9185 with NI 9424 (Digital Input) & 9477 (Digital Output), as far as i understand these modules does not support counters. i am using these modules since the Voltage requirement is 24V and these modules supports it.
2. also, i have NI-6363 Multifunction Daq, i read that these does not support voltages greater than 5V. By any chance is there a way to read 24V input using Ni-6363 counters.
3. in addition to the latency i also need to find the max&min of ON time & OFF time of Digital signal
(633 Views)
My cDAQ knowledge is limited, but...
1. Most digital modules *indirectly* support counter tasks by routing digital signals to the chassis backplane which can also be accessed by the internal counters built into the chassis.  Your chassis has 4 such internal counters.
2.  There are simple logic level-shifting chips that can convert between different digital logic levels, such as 24V -> 5V (and dozens of other options).
3. Counter tasks will be especially useful here.  The 6363 likely supports a convenient "pulse measurement" mode, I don't know either way about your chassis.  But either will support "semi-period" mode, which will yield the same data, but requires a little more manual work in your code to configure and properly handle the data.
    One counter can be used to do your two edge separation measurement.  A second counter can be used to capture a stream of On and Off times that you can analyze.
-Kevin P
(624 Views)
Look up a "resistor divider", this will be very easy to do with a few cents worth of resistors.
(611 Views)
