Find more than one peak in a waform
Hi every body,
Could you please help how I can find the location of the tree most great values (the 3 peaks) of a time serie (waveform) ? thank you 🙂
Best regards
Lahcen
NI Certified LabVIEW Associate Developer
(3,982 Views)
Hi Lahcen,
the WaveformPeakDetection delivers more than one peak!
So where do you have problems with?
Can you attach a VI with typical data to describe your problem?
(3,967 Views)
Hi GerdW,
Thak you for replying.
My problem is that I don't want to specify any threshold. The WaveformPeakDetection vi requires a threshold as input parameter (0 by default).
Waveform Peak Detection
(3,943 Views)
No, it does not require that you wire threshold.
If your peaks all might be below zero, just wire neg inf or some other suitable constant to the threshold.
(3,937 Views)
Hi Perhut,
Yes it's not required in therms of "This Connection is required". But we should specify a value of threshold. So that the VI can do the calculation and find all peaks that are above the threshold and have a width > WIDTH. So thay are relative to the threshold.
What I want is to find the location of exacly the 3 peaks without specify any threshold.
(3,930 Views)
Accepted by Lahcen27
Hi Lahcen,
set a (very) low threshold. Then you should get a list of peaks.
Sort this list by peak height and use only the 3 most high peaks…
(3,928 Views)
Good Idea. thank you GerdW 🙂
(3,924 Views)
