Find the closest location in an array of latitude and longitude
 I have a geographical array, and I want to find the closest geographical location based on a given latitude and longitude. For example, if I provide 121.830, 25.1, it should be New Taipei City, Ruifang District. Can someone give me some tips or assistance?
chatGPT said that  can try the following method
Message 1 of 8
(5,663 Views)
Why don't you further refine it and add "do it in LabVIEW"?
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(5,625 Views)
Accepted by koukileo
I just solved this problem. I calculated the distance between two sets of latitude and longitude coordinates and found the location with the shortest distance in the array, which is the geographical name closest to the target latitude and longitude.
Message 3 of 8
(5,611 Views)
Since you are merely interested in proximity and not actual surface distance you can easily solve for the Chord Length between each point in your array and the chosen location.
Chord Length=((dX^2)+(dY^2)+(dZ^2))^0.5
See here for calculating dX, dY and dZ
It's a simple matter the to solve for the chord angle given Diameter = 1 unit Earth and convert to radian Length across a flattish surface with +/-%0.5 accuracy.   Surface distances in the Himalayas will vary more than over calm seas.
Message 4 of 8
(5,610 Views)
that's a good idea!
Message 5 of 8
(5,600 Views)
You are right, I should have tried it myself on labview instead of asking first. thanks for your teaching
Message 6 of 8
(5,597 Views)
Altenbach is sure to post an example using Polar to Complex and simple subtraction to get dTheta and dPhi.  dRho=0 assuming both points are near sea-level.
Message 7 of 8
(5,576 Views)
Darn, I was hoping to see what ChatGPT was going to say about it.  😄
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(5,539 Views)
