Finding Increasing Data
Hello all,
I have a numeric indicator that is displaying numbers (data) that go up and then go down and then go back up and so on. I'd like to find a way to trigger a boolean to say True whenever the data starts increasing but I can't figure out the logic to do that. Any suggestions would be great.
(4,602 Views)
Accepted by winterfresh11
Feedback node to keep track of the previous value and then a Greater Than to do the comparison.
(4,600 Views)
You can keep track of last received value and compare the current value against last one. If current is higher than previous, trigger boolean. You can use either shift register or feedback node to keep last value.
(4,598 Views)
I'm a bit confused on how to use a feedback node to keep track of the previous value
(4,582 Views)
something like this...
(4,569 Views)
Thank you that makes much more sense after seeing how the feedback node should be used!
(4,557 Views)
The posted example should help but here is a link explaining it some more, which also mentions a shipped example.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/feedback-node.html
(4,556 Views)
