Finding a card or cards that allow different scan rates for different channels
I was told that my SCB-68 card did not allow multiple scan rates for different channels. I was wondering what card or cards need to be connected to do this? It may require getting just one more advanced card. I am using LabVIEW to create an application that measures voltage and other stuff.
I have just started using LabVIEW this week and I am really in the dark on this subject.
(2,511 Views)
Greetings:
I'm not aware of any stock cards that allow this function. However, is there any particular reason why over-scanning your "slower" channel/channels is a problem? You can always through out the extraneous data. I've always been of the opinion that it's better to HAVE the data than to WISH you had it! :=) I'd just set your card to scan at the rate necessary to collect your fastest channel, and let the slower channels just collect the extra data points.
Just a thought.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,511 Views)
Greetings:
I'm not aware of any stock cards that allow this function. However, is there any particular reason why over-scanning your "slower" channel/channels is a problem? You can always throw out the extraneous data. I've always been of the opinion that it's better to HAVE the data than to WISH you had it! :=) I'd just set your card to scan at the rate necessary to collect your fastest channel, and let the slower channels just collect the extra data points.
Just a thought.
Eric
Eric P. Nichols
P.O. Box 56235
(2,511 Views)
