Display a color image in front panel.
Hi there,
How do I display a color image in front panel? Which graphic indicator should be used to display a color image? I do not want to use Imaq WindDraw.
Thanks in advance.
Hugh
Message 1 of 19
(5,213 Views)
You can use a picture indicator...(from the graph->controls palette). You find VIs to read in the picture in the picture folder in vi.lib.
Message 2 of 19
(5,213 Views)
I believe you'll find the PICTURE functions very useful for this. The nice thing about the picture functions is that you can keep daisy-chaining them together to add features....such as a grid, or a cursor, or even a photographic background. You can even animate the colors. Look in the Examples in the help files. They're pretty good.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
Message 3 of 19
(5,213 Views)
Try this "draw flatten jpg to pic ctrl.vi"
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 4 of 19
(5,213 Views)
Thank you for your VI. It works well. I need some time to understand it. I have many years experience in Labview and very new to color imaging. A quick question: How do I display a image in a fixed picture control no matter image's spatial resolution.
Thanks again.
Hugh
Message 5 of 19
(5,213 Views)
Thanks very much, Mads. I will take a look at the picture control.
Hugh
Message 6 of 19
(5,213 Views)
Thank you very much, Eric, for your help. I will take a look at the examples.
Hugh
Message 7 of 19
(5,213 Views)
Me too, not really having much exp. in color imaging.
I am not sure if I understand your question, but if I do, fixing the property node "DrawAreaSize" for picture control should do the job.
Hope this is not a nonsense :<
Cheers!
Others might be able to give you a better answer.
Ian F
依恩与LabVIEW
Message 8 of 19
(5,213 Views)
Hi Ian,
Hope I did not mess up your name. DrawAreaSize does not do exactly what I want. My question was how to fit a image into a picture control in fixed size. Picture control does not resize itself to fit the images in different spatial resolution. Thanks again.
Hugh
Message 9 of 19
(5,213 Views)
My Image Toolbox VIs can resize pixmap data, and display images. Support bmp, gif, jpg, png, tiff, wmf, emf, ico, etc. You can download demo at:
http://gtoolbox.yeah.net
George Zou
George Zou
Message 10 of 19
(5,213 Views)
