Finding all calls to a sub-vi in a project
How do I find all instances of a sub-vi in a LV-8 project? I don't have a "main" vi, but rather a set of independent tests which are called from TestStand. The vi tests are all in a .lvproj (along with the TS sequence) but I can't find a way to search the directory.
Bob
(2,372 Views)
The trick, (at least before LV8) is to make a "master top" vi, wich you never run,
that contains all our top vi's
then its easy to load all your vi to memory, then you  use  Ctrl+F (Edit->Find)
you get your list, and can step to all places with ctrl+G
(2,370 Views)
