Finding interpolated peaks with peak detector.
I am having trouble accurately finding the peak in my data using the Peak Detector VI.  I want to find the interpolated peak in a data set with one major peak with some noise across the spectrum.  When I increase the width parameter,  the peak is shifted from the actual location. I have tried filtering the data without much success  either.  See attached vi that contains a sample data set and what I have been trying so far.
TB
(2,846 Views)
Hello TB,
This is expected behavior.  If you read the LabVIEW 8.20 Help, it says "Large widths can reduce the apparent amplitude of peaks and shift the apparent location."  I would experiment with your width control value until it is accurately selecting the peak values.
Have a great weekend!
Janell R | Applications Engineer
(2,824 Views)
What if m width location is 3 (lowest accepted minimum) and my peak locations are still shifted? I have read through many threads on this and I can't get everything to line up. I've posted my own thread about this but it appears to be getting no attention, maybe because this has been a problem so much
(2,490 Views)
