How to convert a audio file to text file
Hi all ,I want to convert audio speech say"I love you" now I want to write this speech on a text file ?
I want answer with reference to speech recognition plz help me.
Thanks in Advance.
(5,131 Views)
sattu;
An alternative is to check the following:
Voice Recognition in LabVIEW
Regards;
Enrique
www.vartortech.com
(5,131 Views)
Thanks in Advance.
I down-loaded Express Scribe from NCH (u need speech recognition already set up -USE ID 0) -options, speech-to-text. I used a sync folder (read the help from the program) the program will down-load whatever additional software it needs (e.g.. ffmp3 if you are using MP3 format). I used conversion software and output to the sync folder (the program automatically detects (or click the synch button) then will convert the speech (speech-to-text in notes section) I let it run overnight (7 hours) it completed all 10 (each 1 hour long) class lectures. The text is not perfect but it is easier to change or delete the parts I don't need for lecture notes.
(4,691 Views)
http://en.wikipedia.org/wiki/List_of_speech_recognition_software
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,397 Views)
