Finding minimum value from spreadsheet
I want to find minimum value from already saved spreadsheet (B column) containing about 300 readings. Also how to find minimunvalue of XY-Graph and its corresponding index.
Message 1 of 34
(5,515 Views)
Hi jyotia,
  Can you attach your spreadsheet also?
Thanks and regards
Srikrishna
Message 2 of 34
(5,504 Views)
read the whole array of column B from the spread sheet and use the function MIN and MAX value from the array's plate.
Regards
Message 3 of 34
(5,498 Views)
This is my readings' spreadsheet file attached over here. I want to calculate minimum value of column D.
Message 4 of 34
(5,489 Views)
Hi jyotia,
  I am attaching a VI which will read your excel sheet and disaply the minimum value as well as minimum index.
Thanks and regards,
srikrishnaNF
(remember program is in Labview 9.0)
Srikrishna
Message 5 of 34
(5,487 Views)
Thank You ShrikrishnaNF,
but the problem is, I dont have LabVIEW9 in my lab. So can you please help me with 8.5 version.
Message 6 of 34
(5,482 Views)
Hi jyotia,
  Here it is the VI with labview 8.5 version
Thanks and regards,
srikrishnaNF
Message Edited by srikrishnaNF on 03-17-2010 07:27 AM
Srikrishna
Message 7 of 34
(5,478 Views)
Thank you very much ShrikrishnaNF for Read Excel code.
Now I am having another spreadsheet in which graph is also ploted. My aim is to plot column A against column C and calculate area under all individual curve sepatately (there are 12 curves in the graph attached).
Can you please help me with this. (with LabVIEW 8.6)
Message 8 of 34
(5,437 Views)
Hi jyotia,
  I am attaching the VI to calculate the area too.Please find it in the attachments.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 9 of 34
(5,415 Views)
Thank You ShrikrishnaNF for the VI. But the VI sent by you is showing broken arrow. screenshot of error list I am attaching here.
thanx
Message 10 of 34
(5,388 Views)
