Finding the hwnd of a listbox
I am using a Call Library Function Node to start another program. I have a listbox on the front panel and I need to find the hwnd that corresponds to the listbox in order to send debug messages from the other program to LabVIEW. I would appreciate any help I can get. Thanks.
(4,081 Views)
See the post here about hwnd's of LabVIEW controls. Can you modify the DLL? Instead of using messaging, you can use the LabVIEW ActiveX method Set Control Value.
(4,078 Views)
If you know window programming, you can create a listbox, a true window object, on the front panel at run time, then
you get the "hWnd" in return.
George Zou
http://gtoolbox.yeah.net
George Zou
(4,081 Views)
George,
Shouldn't this created object (listbox) be updated when the window receives
a WM_PAINT message?
Normally, aren't controls updated between the BeginPaint and EndPaint
calls,when handling the WM_PAINT message?
I think I saw some programs from your hand, that draw graphics (GDI) on the
front panel of a vi. When I did this, the graphics would disapear when the
front panel gets redawn. How did you get around this?
Wiebe.
"zou" wrote in message
news:5065000000050000002AD80000-1042324653000@exchange.ni.com...
> George Zou
(4,080 Views)
If the listbox is a true window object, then you don't
have to worry about paint event. Unless you want to do
some fancy "owner draw".
Use BeginPaint/EndPaint only in window procedure when
you create your own window, while Listbox is window pre-
defined class.
In my VIs, there are 2 different types: those create an
child window,and those draw directly on the front panel.
If one draw something on an exist window, such as a
front panel, then he has to catch the redraw event of
that window, and paint again. Otherwise, graphics
"disappear".
George Zou
George Zou
(4,080 Views)
Thanks.
I tried to get the window handler of an activex container, like Greg
McKaskle described in the link Dennis Knutson send. This works fine! Have
you ever tried to subclass a activex component by filtering messages?
Wiebe.
news:50650000000500000078D80000-1042324653000@exchange.ni.com...
> defined class.
> If o
> "disappear".
> George Zou
(4,081 Views)
Dennis's old Exchange link above (that Wiebe "just" referred to) is now dead.  Here's the updated link to Greg's discussion.
Message Edited by LabBEAN on 12-29-2009 11:55 AM
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(3,485 Views)
