Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Firewire on ETS PC?
Firewire on ETS PC?
afinemetsfan1
Member
11-05-2006
10:03 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am in the process of researching an inexpensive real-time solution using a PC. I would like to use firewire camera inputs to the ETS PC. Does ETS work with the PC's onboard firewire, or will it only work with the PCI-8252?
Kudos
Message
1
of 2
(2,701 Views)
Reply
Re: Firewire on ETS PC?
NathanT
NI Employee (retired)
11-06-2006
01:42 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
AFMF,
The only support for firewire cameras in ETS is found in the drivers for NI hardware, such as the 8252.
NathanT
0
Kudos
Message
2
of 2
(2,688 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
