Fit 2D data in to Circle
altenbach wrote:
(The code would be quite a bit simpler of you would use complex data)
Here's a version that uses complex data. No loops! 😄
Message Edited by altenbach on 03-10-2008 05:27 PM
Message 11 of 30
(4,413 Views)
Thanks for the response, that helped me alot.
Just another question, How can  I show the center value and the radius in the plot ?
Message 12 of 30
(4,382 Views)
There are many possibilties.
To draw a line, you could use image commands with the "Plot images" functionality.
To mark the center you could place a cursor or use annotations.
Message 13 of 30
(4,375 Views)
Thanks for the reply,
I looked at that example but still I am able to do it.Smiley Sad
Could you explain how I can place the marker to show the position of the center and draw a line to show the radius?
Message 14 of 30
(4,324 Views)
An easy solution would be to just draw a third plot from the center to the circle. If you use a plot with visible point style, the center will show up just fine. Modify as needed.
Message Edited by altenbach on 04-03-2008 08:56 AM
Message 15 of 30
(4,315 Views)
Thanks for the response.Smiley Happy Helped alot
Message 16 of 30
(4,300 Views)
this is great; helped me out a lot!
I'm trying to background substract the form of a circle from data we acquire and was wondering if you know what the best way to do that is.
We're working with x,y data (cartesian coordinate system) and have used polynomials in the past but they can remove some fine structure from the data.
Polynomials also aren't consistent with the expected shape of the data; should be an arc, but not like Noah's! ....so its more accurate to use the equation of a circle than the polynomials.
So the data we have is in the form of an arc of a circle (not a full circle) with a typical arc angle range between 35 -145 degrees.
I've attached a block diagram snapshot of my best attempt so far but it seems that the the form corrected data is very close (if not identical) to what I get when using a 2nd order polynomial! Not sure if thats correct (expected it to be a bit different) but figure there must  be an error in my approach.
Have been troubleshooting for some time and have been literally going in circles trying to figure out what I've messed up.
Any help would be appreciated.....thanks!
best
SS
Message 17 of 30
(4,130 Views)
Can you show us some typical data or even attach your VI (containing some typical data). How many degrees does you "arc" cover? If it's just a shallow "banana", a second order polynomial should work equally well.
The circle fit is much more universal and works even in the case where you have multiple distinct y's for some of the x (e.g. if the arc is near vertical).
Message 18 of 30
(4,127 Views)
Yup I'll post sample data and the vi tomorrow....
The angle range that the arc covers is generally between 35 -145 degrees.
best
SS
Message 19 of 30
(4,122 Views)
OK I've attached a the VI with some sample data (should be the default values).
I've tried to figure out what was wrong and think I made the form fit worse! Not sure what I changed but the form subtraction doesn't seem to do anything....
thanks for the help...
best
SS
Message 20 of 30
(4,102 Views)
