I assume you are trying to find a gaussian ditribution function to fit to the data. All you need is to find the average and the sample standard deviation of your data and then build the Gaussian function. You can plot that, you can also plot a histogram of your data to compare to the Gaussian plot.
With little programming code, you should be able to do that.
