Fitting data with 'gaps' in
Hello all,
This may sound a very simple problem but I've been stuck for a short while. Basically I have a data set, see attached, and I want to cut out the peak and fit a polynomial to whats left.
I can see two ways to cut out the middle, by either replacing part of the array with NaNs (non-plottable) or simply deleting the offending section.
Neither seem to produce a new array which lend itself to fitting, I've attached my VI which can do both (needs a rewire to use either for fitting..).
Any ideas?
David.
Message 1 of 8
(4,487 Views)
I am posting via phone, so I cannot look at your data. All fitting vi's take xy data. So all you need is to create a new xy data set, containing the retained indices as x and the retained data as y.
Message 2 of 8
(4,473 Views)
I think I got what you were looking for. Look at the example that I added and see if this does what you want.
Tim
GHSP
Message 3 of 8
(4,472 Views)
Thanks for your quick replies. However, aeastet, your VI isn't quite what I'm after.
I know its slightly annoying when people use screen grabs, but if you have a quick look at the one attched - from Origin 7- there I can use a data set with missing y-values to fit. This is what I want to do with my data after I have removed the peak - I'm pretty sure just deleting that part of the array is not the way to go so I've edited my VI accordingly.
After fitting I intend to use the fit as a background to get an absorbtion spectrum, then do further fitting (which I can do okay with another VI - I think!).
Is this any clearer?
Many thanks again.
D.
Message 4 of 8
(4,442 Views)
Use "polynomial evaluation" using the found coefficients to generate the data for any x-values you possibly want. 😄
Message 5 of 8
(4,412 Views)
Accepted by SDmanc
Try this.... (LV 2010)
Message 6 of 8
(4,403 Views)
That is, exactly, what i was after. Many, many thanks.
Message 7 of 8
(4,392 Views)
Here's a much better way. Simply set the weight of the undesired points to zero. 😄
(Modify as needed, there are many things still to improve.)
Message 8 of 8
(4,382 Views)
