Fixed-Point bug in LabView?
I'm currently working on a FPGA project in LabView and encountered something odd that seems like a bug, but it could also just be me not fully understanding how fixed-point numbers are supposed to work. I'm working in LabView 2010 Pro (10.0f2 32-bit) on Win 7 Ent. 64-bit.
The problem I have is that when I try to add certain numbers together I get unexpected answers, which of course makes the code very unreliable.
For example: If you try to Add 0.50002 with -0.49998 you would expect something around zero, but instead you get like 3.99999.... Am I missing something here? I've seen this on several numbers around zero. Does fixed-points not work around zero?
I should add that I've just tried this on the local machine and not on the FPGA, but I don't see that would make any difference. Both inputs are set to 'Adapt to entered data' and the output is 'Adapt to source', the Add-function is also set to 'Adapt to source' and I've tried both Wrap and Saturate.. I've also tried with fixed bits instead of Adapt to entered data on the inputs etc. with no luck.
Can anyone shred some light on this please? Is it just me or is it really a bug or just as fixed-point numbers are supposed to work?
Thanks!
/Joel
Message 1 of 9
(5,770 Views)
Are you certain your FXP isn't unsigned? If it's unsiged that -0.5 will be a rather big number. 🙂
Can you post a VI showing the issue?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(5,757 Views)
Thanks for your reply.
No it's set to 'Adapt to entered data', but I've tried with setting it to signed (32/1 bit) also and it makes no difference.
I attached the simple vi. I get same weird result for many numbers I try so don't know what's wrong..
/Joel
Message 3 of 9
(5,752 Views)
I concur, even 0,50001-0,5 yields 7,999 or something crazy.
/Y
Qestit Systems
Message 4 of 9
(5,744 Views)
You can get around it by typecasting the answer to a FXP of appropriate format.
/Y
Qestit Systems
Message 5 of 9
(5,730 Views)
You mean by putting a 'Type Cast' after the 'Add'? Maybe, but that's not reasonable to do after every single aritmetic operation in a large program 😉
I don't know if I dare using fixed-points at all now if it's really a bug, it could cause some nasty results...  But then if it is bug loads of people should have noticed it already I guess, so there has to be some explanation 😛
Message 6 of 9
(5,725 Views)
Accepted by Elrahir
It is not a bug.  If you expand the indicator displaying the result, you will see that there is an exponent of -5 at the end (e-5 = 10^-5).    So it is telling you the answer is 4*10^-5 or 0.00004, which is pretty close to 0.
Message 7 of 9
(5,715 Views)
Ohhhh... *facepalm*
Haha thanks, that explains it 😉
Message 8 of 9
(5,712 Views)
@Elrahir wrote:
Ohhhh... *facepalm*
Smiley Very HappySmiley Very Happy
That comment just made my morning!  Thanks.  For some reason I've got a vision in my mind from a vegetable drink commercial.
"Oh! (*facepalm* ) I could've had a VU8."
Message 9 of 9
(5,640 Views)
