Fixed number of lines in a string
I am trying to have a fixed number of lines in a string control.
Regardless of number of lines  entered in the string control, it should write say 10 lines to a text file.
So it should add blanks if user enters < 10 lines and chop off if number of lines entered are > 10.
(2,833 Views)
Accepted by zezendapuss
Hi zenzendapuss,
in your other thread you got several suggestions to get the number of lines in your string. Don't you use any of theses methods?
I suggest:
- convert the string into an array of strings using SpreadsheetStringToArray with NL as delimiter
- limit the resulting array to have exactly 10 elements (aka lines), using ArraySubset after appending another 10 elements (containing empty strings)
- convert the array back to your string (or write directly to your file)…
Example:
(2,818 Views)
