Fixing a NXT LabVIEW Toolkit compile/load problem
I bought myself a Lego NXT Mindstorms to play with. I'm using the LabVIEW 8.5.1 from the FIRST Robotics competition and I downloaded the NXT Toolkit for Labview.
I did a mass compile on the toolkit (like the getting started said to) and did the excersize. I get the following error:
Error 1003 occured at Invoke node in NXT Toolkit.CompileOrCancel.vi->NXTToolkit.Target.Agent.vi
Possible Reasons:
LabVIEW: The VI is not executable... It said to do a file->open.
Method Name: Run VI
VI Path: C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\gcomplier\Backend.LEGO\NXT.Compiler.Core.vi
The vi was broken but it had a password to open the view so I couldn't tell what was going on.
What do I do to fix this?
"Lockheed" Joe
Testing Blog"
(3,218 Views)
Hey Joe,
The Lego NXT Mindstorms and the LabVIEW Toolkit for the Mindstorms are officially supported by Lego's Technical Support. Check out this knowledgebase for a little more information regarding how to get the quickest support for your Mindstorms NXT issue.
Hope this helps,
Ben
Hope this helps.
-Ben
WaterlooLabs
(3,177 Views)
