04-06-2009 07:11 AM
On the CLAD sample online exams a question appears as follows:
Which of the following functions assembles CLuster elements by their owned label
a bundle
b unbundle
c unbundle by name
d bundle by name
My question is:
Obviously the answer is a or d but d cannot assemble a cluster while a does not bundle them by their owned labels.
Any ideas?
Sean
Solved! Go to Solution.
04-06-2009 07:15 AM - edited 04-06-2009 07:16 AM
04-06-2009 07:38 AM
04-06-2009 07:46 AM - edited 04-06-2009 07:47 AM
SeanMcM wrote:...
a bundle
b unbundle
c unbundle by name
d bundle by name
So while working in one of my regular labs the lead lab-Tech was rambling on about trivia as he ussually does when he started explaining that palacene (sp? modeling clay) is higly resistive to acids and other caustic gasses. He goes on to mention that "we use it to seal up leaks in the tear-gas hood...". So i look him in the eye and tell him "Jay, God help me if I ever need to know what I learn from you!"
So why would I tell that story here?
After reading the Q and reply I could not help but think,
"God help me if I ever have to answer a question like that!"
Ben
PS I agree with Dennis. The only way to know what the real answer should be is to find out what the original questioner had in mind when they wrote that Q.
04-06-2009 07:48 AM
Thanks Dennis and Thoric,
I'm still inclined to favor Thoric's answer, because although it does not sort them by name one can still extract the name.
It's a pretty nebulous question. I blame NI!
There's a whole pile more verty tricky ones like that and the worst thing is they don't give the answers!
e.g. where can you insert an indicator?
a. block diagram
b. front panel
c. both
d. neither
It has to be c, I hope, although you won't find an indicator on the functions panel you can create an indciator by right clicking on a function and create indicator. They're tricky!
Sean
04-06-2009 07:52 AM
Ben,
I totally agree but unfortunately in order to pass the exam I have to answer the questions that they pose and not argue the validity of the queation!
2 hours 9min to the exam!
Sean
04-06-2009 07:53 AM
After re-reading the question carefully, I think you might be right Dennis.
"Which of the following functions assembles Cluster elements by their owned label", not "including their owned label"
The only way to bundle by the label, of course, is to use a "bundle by label" and provide a template for the input cluster terminal. With a simple bundle function, as you say, you get a cluster which contain labels, but they haven't actually been bundled by label, instead they're bundled by the order in which they've been wired to the bundle function.
04-06-2009 07:55 AM
SeanMcM wrote:Ben,
Sean
Then go with the answer from Dennis.
Thoric's reply is just too subtle for the the question writter to know that little piece of trivia.
Ben
04-06-2009 08:05 AM
Ben,
I'm going with Thoric's first answer, I think, it is not possible to assemble a cluster using bundle by name.
See attached file
thanks for your help
Sean
04-06-2009 08:35 AM
You will if you use a merge VI which includes an indicator. I would say that the strict answer would be B but the correct answer would be C.
Both questions are phrased badly, like many of the others, and people have been vocal in complaining about this sort of thing.
As for the original question, I'm also assuming that whoever wrote the question was thinking of the BBN. The use of the term "assemble" is simply confusing.
