Flat Sequence Next Frame
Hey all,
I'm working on a very simple program on LabVIEW using flat sequences. In the first frame, the user must enter information about himself. I did that using the prompt input from user vi. Just after the user enters his information, I want the program to take me to the front panel where the user sees some waveform. The main problem that I'm facing is that when the user finishes entering his information in the pop-up window, the program remains where it is and does not move to the next step where the user sees information
I hope someone can help me
Thank you
Message 1 of 9
(4,695 Views)
Post your vi. We cannot help you otherwise. I can tell from what you said that is seems that you do not use preferred Labview programming practices...
Marc Dubois
Message 2 of 9
(4,690 Views)
The main VI is called Installer.vi which calls a subvi (Final Input Vi).
When the program finishes from the first task in the flat sequence (User enters data), I want the program to immediately display the next task (which is when the user must press the start button to see the graph)
Thank you a lot for your kind help
Message 3 of 9
(4,671 Views)
I don't see the problem. You have the first frame that is executed (requesting data from the user), then the user must press the button "Start", and then the sine is displayed in the graph. What is it that does not work? If you want the sine displayed right after the dialog, why don't you simply put the Sine function in the second frame?
Marc Dubois
Message 4 of 9
(4,645 Views)
@md001 wrote:
I don't see the problem....
  • and the improper use of flat sequences and understanding data flow
Message 5 of 9
(4,639 Views)
Not the best way to go but the VI waits until the user presses "Start". Isn't that what you want to do?
Marc Dubois
Message 6 of 9
(4,632 Views)
You are well advised to start with some tutorials and learn about state machine architecture. For example don't you want to branch into a different state when the dialog gets cancelled by the user, for example? Why do you unconditionally rattle through unskippable sequence frames?
Why do you think you need a cpu burner loop that consumes 100% of the CPU doing nothing? (See also here).
Add an error input output to your subVI and you can eliminate the entire sequence stucture.
Message 7 of 9
(4,631 Views)
@md001 wrote:
...Isn't that what you want to do?
No...
one could easily translate flat sequenced events to a simple state machine. i remember that there was a web cast tutorial showing how to do this?
Message 8 of 9
(4,618 Views)
I don't think that everyone needs to become an expert before starting using Labview. The understanding of the benefits of design patterns comes with use and experience of Labview. There is not point explaining data flow or design patterns if someone does not understand a flat sequence for example.
Marc Dubois
Message 9 of 9
(4,608 Views)
