Flat Sequence Structure inside Timed Loop
Block diagram errors:
Time Structures aren't allowed in Time Critical VIs since such VIs have higher priority than Timed Structures, leading to unreliable Timed Structure operation.
How can i solve it?
Message 1 of 9
(5,180 Views)
@Zhangfy wrote:
How can i solve it?
Don't set the priority to time critical?
Message 2 of 9
(5,178 Views)
How can i set the priority in order not to time critical? thanks
Message 3 of 9
(5,176 Views)
VI Properties---Execution
Message 4 of 9
(5,170 Views)
I hate to deflate your ego, but your post is NOT the solution.
Bill
CLD
(Mid-Level minion.)
Message 5 of 9
(5,140 Views)
you can not choose time critical priority for the VI, which has already timed loop structure inside.
If you need timed loop in your application, then please do not choose time critical priority in execution.
Manikandan
Message 6 of 9
(5,133 Views)
Thank you all very much! The problem is solved by setting!
Message 7 of 9
(5,070 Views)
Of course not using a flat sequence structure would also help. EDIT: Never mind, the title and content of the OP are a bit off.
Message 8 of 9
(5,058 Views)
Setting priority to normal priority from VI properties inside the file button.
Message 9 of 9
(2,426 Views)
