Hello%
Scan From String:
Input string: %Hello
format: %%%s
Output: Hello
My Problem:
Input String: %Hello%
format: ?
Output: Hello
(1,060 Views)
Accepted by topic author maxnoder1995
%%%[^%] is sufficient.
%%%[^%]%% if the last % is required.
See Format Specifier Syntax
Spoiler
  • [ ]—Characters in set. [ ] matches a string that contains only the characters specified between the brackets. Character matches are case sensitive. The [ ] conversion code is useful only when you are scanning strings. To match the caret symbol (^) in a set, make sure it is not the first character after the bracket. The following examples demonstrate the use of the characters in set conversion code:
    • %[aeiou]—Matches any string that contains only lowercase vowels.
    • %[0-9a-zA-Z ]—Matches a string that contains numbers, letters, or spaces. You can use a hyphen to specify ranges of characters in the set.
    • %[^,;]—Matches any string of characters up to but not including the first comma or semicolon.
 If the parameter represented by Hello can also contain a %, then use "Match Pattern" or "Match Regular Expression" instead to allow backtracking.
(1,045 Views)
