Flatten to XML error
Is there a limitation with the length of the string when using the Flatten to XML function in LabVIEW (using 2019 on Win 10). When the length of one of the class member fields is >255, LabVIEW stops with the following error message:
Any inputs?
(2,155 Views)
I think it's an xml limitation.
Bill
CLD
(Mid-Level minion.)
(2,139 Views)
Hi Bill
Thanks for the response. I could, however, not find any documentation that specifically mentions this limit.
If you know of something specific, could you please point it out. Will keep trying on my end as well.
Regards
(2,137 Views)
My input was as invalid as your input error.  I re-read what I saw and it was talking about datatypes, and I got confused about characters, chars, bytes and lengths.
Bill
CLD
(Mid-Level minion.)
(2,131 Views)
Sorry, did not understand what you meant by this:
"My input was as invalid as your input error."
So it does not seem to be an XML limitation?
(2,122 Views)
It was my way of saying that I was wrong.  😄
Bill
CLD
(Mid-Level minion.)
(2,085 Views)
