Flickering Table
I have a table indicator which updates 5 times every second. During the
updates, I changes some of the cell's text values and background colors.
When I run my routine, the table flickers as it updates. If the table is
the slightest bit occluded by another control, it updates smoothly. How can
I prevent my table from flickering without clumbsily putting a control on
top of it?
Peter
Message 1 of 15
(6,601 Views)
> top of it?
The table control flicker is due to it drawing everything to the screen each
time. This allows you to see the various stages and gives a bit of a flicker.
Some of the controls, like the graph have a popup for smooth updates
that will
force them to draw everything offscreen, then copy to the screen. This can
slow down execution, but makes things flicker much less.
The
table doesn't have any such popup yet. As you noticed, if an object is
above the content rectangle of the table, the table will not draw to the
screen directly, but will do what we call an invalidation. If the Tools
Options menu is set to draw offscreen, then all of the flickering will
go away.
Another way to accomplish this is to make the table largely transparent.
If the table is just an indicator, the easiest approach is to place a decoration
over the table and make the decoration transparent. I think the hollow decorations
will do the same thing.
Greg McKaskle
Message 2 of 15
(6,601 Views)
Thanks for the information. I did place a decoration over the table and
made it transparent. It works perfectly.
Peter
"Greg McKaskle" wrote in message
news:3B7331C6.BB4ACD12@austin.rr.com...
is
can
on
> > top of it?
each
flicker.
> that will
can
> The table doesn't have any such popup yet. As you noticed, if an object
is
> go away.
decoration
decorations
> Greg McKaskle
Message 3 of 15
(6,601 Views)
I've had success with this by selecting one of blocked indicators or controls and selecting 'Move to back' or 'Move to front', as applicable.
Message 4 of 15
(6,601 Views)
I had a similar issue with a rapidly (50 times/sec) updating table.  Based on the suggestions in this tread I added a decoration frame at the edge of the table.  It worked like a charm - no flicker, scroll bars are still accessible, and it doesn't look half bad either.  Thanks to Greg for the helpful information.
Message 5 of 15
(6,148 Views)
WOW! It really works!
Message 6 of 15
(5,466 Views)
Yes, but that is no longer the prefered solution!  (It is 14 years old afer all)
Better: Drop invoke nodes before and after the table value updates and select method "Defer FP Updates" Set True before and False after.
The help file will tell you more but essentially this forces any updates to the FP to happen, Stops updating the FP, Allows you to transfer a whole bunch of data to get ready for display and then makes all of the updates at the same time.
Message 7 of 15
(5,459 Views)
For some reason, the deferfpupdate property does not work in my application. Only the decoration works.
Message 8 of 15
(5,442 Views)
Lets see some code.... you might have other problems.  Feel free to start a new thread to address your issue.
Message 9 of 15
(5,431 Views)
How often does the data change in the table and how often does it get updated? What is your loop rate?
Message 10 of 15
(5,423 Views)
