Flickering Table
Also note that depending on how you look at it, the property works backwards -- or at least I always felt it did. To stop updates you set it true, and to restart updates you set it false.
Yes, yes I know that given the way it's labeled it is really correct, but it still feels backwards to me...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(1,331 Views)
It appears writing to the local variable of the table is causing the flicking.  If it is writing to the Value property node of the table, the flickering is gone.  So maybe writing to local variable force-triggers the front panel update?
Message 12 of 15
(1,295 Views)
You are feeding us small bits of additional information every time you post... Why don't you provide all relevant information at once?
Is your table a control or an indicator? Why aren't you writing to the terminal directly? How big is the table?
(note that NI decided to make tables controls by default, so you need to change them to indicators for typical use (right-click...change to indicator. If you think this should be changed, vote for my idea here ;)))
It would help us all to gauge the problem if you would just attach a simplified version of your VI. Please do so! Thanks. There are several other settings that could be part of the problem.
Message 13 of 15
(1,288 Views)
Here is the sample code.
Message 14 of 15
(1,268 Views)
By looking at his VI.
The table is an indicator.
It is only 24 elements , 4 columns by 6 rows.
He is writing to the terminal.  It does show some flickering.
There is a 50 msec wait after every 10 updates.
Putting a small decoration over part of the indicator does seem to stop the flickering.
Writing to the Value property mode does seem to stop the flickering.
There is no local variable in the VI, but when I add one, it also flickers.
Deferring front panel updates doesn't seem to help.
Message 15 of 15
(1,262 Views)
