Floating point numbers into XML file
I am a learner in Labview and I am using Labview 8.5 version.
when I use FlattentoXML component to convert floating point numbers ( having more than 5 decimal points) into XML, the output contains alway 5 decimal points.
But, I want exact decimal number to be displayed as XML. i.e 0.263746 should not be displayed as 0.26375 in XML.
Do you have any suggestions ?
Message 1 of 8
(4,849 Views)
you can use "Flatten To XML"
Message 2 of 8
(4,835 Views)
20341i65BF6FB49F1DEF30
Message 3 of 8
(4,830 Views)
If your output is a number then use a "format into string"
20343i481701FC89EA1E7C
Message 4 of 8
(4,827 Views)
I would like to receive an XML output like this.
Could you tell how it can be acheived ?
<DBL>
<Name></Name>
<Val>0.79857935879</Val>
</DBL>
Message 5 of 8
(4,823 Views)
Simple define like this
20349iE2EDD84AB137D272
Message 6 of 8
(4,819 Views)
I tested it and could not see your problem in Labview 2009. So it is perhaps a bug in your Labview version. You can use this VI as a workaround.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 8
(4,814 Views)
I checked in LabVIEW 8.6.1 and the XML reports 11 decimal places.
See this post regarding five places of precision:
Floating point precision of "Flatten to XML"
If you're using 8.5, this issue may have been fixed in 8.6...
Message 8 of 8
(4,794 Views)
