Font size on Mac vs. Windows (again)
This is an old issue, but I have not found a satisfactory explanation, let alone solution: the exact same font renders roughly 10% larger on a Mac than on Windows - see attached example (Arial, bold, 120pt).
I've seen two explanations of why fonts render differently on Mac and Windows:
I should mention that I ran the same experiment with MS Word on Mac and Windows, and I got roughly the same result as in LabVIEW. So I'm convinced that it's an OS issue – but it so happens that I need to fi it for my LabVIEW application!
So:
  • Can anyone explain what's going on?
  • Does anyone have any suggestions on how to fix it, or at least minimize it?
Thanks in advance!
-- Phil
P.S. Please don't tell me to use another font; all the fonts common to Windows and Mac seem to have about the same behavior. Also, please don't tell me to use the LabVIEW's System font; that doesn't fix the problem either.
(5,108 Views)
I would first verify the two dpi settings.  The dpi settings are changeable.
In terms of fonts, LV can not even get along with other Windows programs, I am not sure it will ever get along with Macs as well.
What LV calls pt is unfortunately px actually.  Drives me nuts, pt is a well defined unit (72 pt = 1 inch), px is not a unit of length.  My own observations are consistent with the 96 versus 72 dpi difference between Macs and Windows (by default).  My Mac VIs used a 10 "pt" font which would have me squinting on Windows where I use 15-16 "pt".  If you are only seeing a 10% difference I count you as lucky.
(5,082 Views)
我跟你一样的感觉,pt实际是px,我还以为是中文版的翻译错误
(3,625 Views)
Old thread, but i assume it's still the same. Windows usually have a scaling of 125%, which would result in about 15% difference which seems close to what Keller was seeing.
Qestit Systems
Certified-LabVIEW-Developer
(3,601 Views)
