resgister for event on multiple boolean refs
Hi all,
Can anyone explain the broken wire in the attached vi?
LV2014SP1 64b
It seems that LabVIEW won't accept to register a value change event on a cluster containing more than 1 boolean control ref, unless there is also a non boolean control ref in the cluster.
Weird, no?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 1 of 15
(5,195 Views)
I was able to duplicate on LV 2015 32 bit.
Also, it seems to have something to do with the order of the cluster.  See:
Message 2 of 15
(5,177 Views)
The Mechanical Action plays a role here.
Change to "switch" rather than "latch" and all variations work.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 3 of 15
(5,169 Views)
Try adding a cluster to array in the broken case as a work around
Message 4 of 15
(5,165 Views)
Hi!
OEM_Dev seems to be right. Using a build array instead of a build cluster function helps to workaround.
I will look a little closer at the issue and file a CAR if necessary.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 5 of 15
(5,127 Views)
Steve,
Shouldn't it work whatever the mechanical action? I think it should.
And :
1 switch : ok
1 latch : ok
1 switch & 1 latch : ok
2 switch & 1 latch : not ok
2 switch & 2 latch : not ok
2 switch & 2 latch & 1 num : ok
Epictetus
Antoine Chalons
Message 6 of 15
(5,125 Views)
Christoph,
Replacing the build cluster with a build array confuses me... how do I do then to set my event structure to catch each separate value change?
Epictetus
Antoine Chalons
Message 7 of 15
(5,122 Views)
> Steve,
Agreed. I just wanted to add a data point for investigators.
steve
Message 8 of 15
(5,106 Views)
I don't use dynamic events much, but my understanding was that either an array or a cluster would be used to run a single event frame when the specified event happens on any of the specified controls.
Message 9 of 15
(5,093 Views)
Use the "CtlRef" output inside the structure to find out which one was pressed.  Here I use a "Search 1D array" to find the index, but you could also get the label text or use any other property node you feel like.
Message 10 of 15
(5,076 Views)
