For Labviewguru: details
impossible to send you the details. I've got a message delivery failed!!??
How can I do? Which adress could I use?
JL
(2,926 Views)
I tried the email address, it works fine for me.
Try this one instead:
labviewguru@nethere.net
(2,926 Views)
Hello Mr. GURU!
First of all, sorry about this answer, because it is not an answer, it is a question. I have looked around the NI ZONE looking the answer for a question, and i have seen, that you are the person that know more about that. So sorry again, by asking directly to you.
We are developing an app. In this app we save all the data in a file. At the beginning of the application, a dialog box opens, and ask you where to save all the data. OK, my problem comes when i run the application from another computer (client computer). When I do that this dialog box does not opens, but when I run the app from the server this dielog box opens. What can I do?
I leave an example of what we are doing. In this example yo have to push the star button, then th
e dialog box appears (you have to say where you want to save what you write), then you write something in the panel ("text to save"), and finally, you push the "save" button. But when you try to connect from another computer (trough a browser) and you gain the control of the application, when you push the "start" button, no dialog box appears.What can I do?
I hope that i have been clear enough. Thanks again alot for helping me.
Thanks a lot
(2,926 Views)
