dll
I use "Call Library Function Node"in LabVIEW6.1,and this is the .c file in VC++
/* Call Library Source File */
#include extcode.h
_declspec(dllexport) long avg_num(float a[], long size, float *avg);
/* Insert Code Here */
int i;
float sum=0;
if(a != NULL)
for(i=0;i < size; i++)
sum = sum + a[i];
else
return (1);
*avg = sum / size;
return (0);
But I get the following error:
f:\mydocument\labview\myshared.c(3) : fatal error C1083: Cannot open include file: 'extcode.h': No such file or directory
(3,320 Views)
nuaa;
The error is saying that it could not find the 'extcode.h' header file.
Make sure you tell VC++ where the .h file is. In VC++, go to "Project -> Settings...", change the "Settings For:" to "All Configurations"; select the "C/C++" tab; in the "Category" field select "Preprocessor" and in the "Additional Include Directories" type the path to the extcode.h file. This is usually \cintools.
Regards;
Enrique
www.vartortech.com
(3,320 Views)
