For loop Auto Index should not index empty array
Hi guys,
In this VI, I meant to remove empty elements in array. It worked for 1D array but as soon as I gave it 2D array, for some reason I was unable to remove empty elements:
(6,730 Views)
Try transposing the array before and after the for loop. Looks to me like it is indexing the other way round from what you expected...
Remember Cunningham's Law
(6,718 Views)
Hi cryptic username,
in an 2D array ALL rows need to have the same number of columns!
So even when you delete elements from row 2 it will still have two (empty) elements when row 1 has two ("non-empty") elements!
When you want to remove rows as well you need the same conditional output tunnel as you already use for the columns in the inner loop…
(6,684 Views)
Hi GerdW,
So when I was debugging, I saw at the 3rd row and 4th row iteration, the output from inner FOR loop to index terminal of outter FOR loop is [].
I mean what you described definitely applies if [  ]  has some element but in this case it has none. To prove the point, try something like this:
(6,669 Views)
Hi funny username,
 Why should it?
All it has to follow is DATAFLOW!
It always behaves the same way. And it follows DATAFLOW!
Your example is WRONG as you compare apples with oranges!
In your first post you had non-empty 1D arrays and in your last post you have always empty arrays…
(6,659 Views)
Accepted by sdfsdfsdfadgadf
In that case, the indexing tunnel in the outer loop takes an empty 1D array and appends it as a row to the 2D array. Because 2D arrays can't be jagged, it fills the remaining elements of the row (all of them) with the default value. You could possibly argue that an empty array should mean "don't append at all", but this behavior goes back a long way and I'm not sure what kind of effect this would have. As mentioned, it's easy enough to do what you want with a conditional append in the outer loop.
Check the array size. You will find it is 3,0,0. That is, you have 3 pages, each with an empty 2D array, which is exactly what your code builds.
I try to avoid dealing with >2D arrays and dealing with cases where they can be empty, so I don't remember the details of why this happens, but IIRC, it does follow from the rules of the system.
___________________
Try to take over the world!
(6,620 Views)
(6,533 Views)
